hi there. Hope its ok to post here, apologies if not and please move it to a suitable place? Im trying to stack two sessions in sirilic. If i can do that, i should be able to add more sessions. However, i get a problem - my script builds and runs but aborts very near the end. If anyone can suggest a solution, or a more suitable place i can ask for help i'd really appreciate it. end part of log here: log: Saving FITS: file pp_images_00042.fit, 3 layer(s), 5202x3464 pixels, 16 bits log: Sequence processing succeeded. log: Execution time: 52.76 s log: Running command: cd 9: running command cdlog: Setting CWD (Current Working Directory) to 'G:\astro\data\projects\sirilic working folder\M101\DSLR\first go02' log: # log: #TAG#} [8] log: Running command: cd 9: running command cdlog: Setting CWD (Current Working Directory) to 'G:\astro\data\projects\sirilic working folder' log: ################################################################################ log: #TAG#{ [9] Merge ... log: # log: # Group Directory log: Running command: cd 9: running command cdlog: Setting CWD (Current Working Directory) to 'G:\astro\data\projects\sirilic working folder\M101\DSLR\GROUP' log: Running command: merge 9: running command mergelog: Setting CWD (Current Working Directory) to 'G:\astro\data\projects\sirilic working folder\M101\DSLR' log: Checking sequences in the directory: G:\astro\data\projects\sirilic working folder\M101\DSLR. log: No sequence found, verify working directory or change FITS extension in settings (current is .fit) log: No sequence `first' found. log: Could not open sequence `../first' for merging log: Setting CWD (Current Working Directory) to 'G:\astro\data\projects\sirilic working folder\M101\DSLR\GROUP' log: Error in line 136 ('merge'): generic error. log: Exiting batch processing. log: Setting CWD (Current Working Directory) to 'G:\astro\data\projects\sirilic working folder' log: Script execution failed. ~~~ warning:Reading sequence failed, file cannot be opened: offsets.seq. ~~~ warning:Reading sequence failed, file cannot be opened: darks.seq. ~~~ warning:Reading sequence failed, file cannot be opened: flats.seq. ~~~ warning:Reading sequence failed, file cannot be opened: pp_flats.seq. ~~~ warning:Reading sequence failed, file cannot be opened: images.seq. ~~~ warning:Reading sequence failed, file cannot be opened: offsets.seq. ~~~ warning:Reading sequence failed, file cannot be opened: darks.seq. ~~~ warning:Reading sequence failed, file cannot be opened: flats.seq. ~~~ warning:Reading sequence failed, file cannot be opened: pp_flats.seq. ~~~ warning:Reading sequence failed, file cannot be opened: images.seq. |
