How to install GAME script? Pleiades Astrophoto PixInsight · AdrianC. · ... · 9 · 532 · 2
cioc_adrian
I followed the steps http://www.skypixels.at/downloads/PixInsight/scripts/Install_Scripts_Instruction_en.pdf
but I get the error when starting the script:
Processing script file: /home/dan/Downloads/GAME/GAME.js
*** Error: Required code signature not found: /home/dan/Downloads/GAME/GAME.js
TurtleCat 4.62
You need to allow unsigned scripts. Just note that this script hasn’t been updated in years and crashes for many people, especially anyone using a Mac.
Tapfret 4.95
I never did an actually install. I just unzip it in a folder and run "execute script" from the scripts drop down menu and select the GAME.JS file. It's how I run EZ suite now as well.
JimMorse 0.00
Follow these instructions and you should be all set:
     Add this repository under PI's Resource->Updates->Manage Repositories menu.
https://www.skypixels.at/HVB_Repository/
     After you check for updates, install and restart, it'll install a whole pile of scripts into your scripts utilities menu. This describes them all.
https://www.skypixels.at/pixinsight_scripts.html
Hope that helps,
Jim
Psion 0.00
Is the GAME.js script really saved in the scripts folder in PixInsight?
ChemProf 0.00
Yup (to the installation location}.
Works very well for me (under Linux).
Kenward
cioc_adrian
Yes it's there
cioc_adrian
Ian McIntyre:
I get the same error
cioc_adrian
This might be the issue. How do I enable/allow unsigned scripts?
cioc_adrian
I found out how to enable unsigned scripts and now it works.
