5.77
Hello, I am wondering if anybody has ever checked on any pincushion/barrel distortion of the Esprit 100. This question arose during astrometry/plate solving with "Astrometrica" asteroid identification software, where the result was, that my (RAW) image from the Esprit 100 was heavily distorted. I also experienced problems when stitching a mosaic along the small side of the frame to get a 16:9 mosaic (usually, you stitch your mosaics along the long side of your frame). So before I set up a square grid against a bright background in my back yard to take some pictures and check for any pincushion/barrel distortion, I am wondering if anybody has done this yet. Could not find anything seaching on the net. With distortion pictures described above I could work out lens correction parameters in Photoshop before attempting to stitch my images to a mosaik. Thanks & CS! Chris |
9.48
I have not previously heard of this kind of distortion with the Esprit 100ED. I have a couple of questions before the thread goes any further. 1) Could you please confirm that you are using the stock Sky-Watcher 1.0x field flattener with your Esprit 100ED, not a third-party reducer? 2) Could you also show your corner stars (e.g., with aberration inspector) so we can validate that your back-focus distance is correct? Edited to add: It appears that you are using a full-frame camera with your 100 ED. We are therefore talking about having a properly corrected imaging circle for a full frame sensor, correct? Nice images in your gallery... |
5.77
Sorry I did not specify that: Yes, I am using a full frame camera (QHY600L) on my Esprit 100 and yes, I use the original Skywatcher flattener. My Esprit was quality picked and optically optimised by "Teleskop Austria" - but it's all stock parts carefully adjusted for the best performance over the full frame. I have dialed-in my backfocus and tilt adjustment carefully, which was quite an ardous process with such a small pixel full frame camera. But I am happy with my result. Please note that I don't have any difficulties in stitching a mosaic along the long side of the frame, this all works fine. I also don't have any other issues like abberations, or similar. I was just puzzled that somebody using Astrometrica on my frames (that software does a plate solve) statet that my pictures were quite distorted. But I have not experienced any issues with plate solve in NINA (using ASTAP) or in Pixinsight image solver (although the latter sometimes fails, despite having checked "distortion correction"). While I recently experienced some problems with stitching a 2-panel mosaic on the short side of the frames (which is something you usually don't do that often) I thought, maybe I can compensate for any distortions before trying to stitch the mosaic. If nobody has ever done that with the Esprit and the original flattener, I will make some test shots of a square grid and see, if there are any pincushion/barrel distortions. I will post those photos in this thread. Best regards! Chris PS: Thanks for liking my photos! |
Hello Christian! Unfortunately, I can confirm that the flattener from Lacerta/Skywatcher does not manage the full format. Also many discussions with Tommy Nawratil have not led to a satisfactory result. With the 6d anyway a horror, with the Ra, already a little better but still not the yellow of the egg. The only thing that helps is the 2.5 inch version that TS offers. I have only made one pano of the Boogie Man and M78 and that with Apsc. The Esprit is great, as long as you don't mind the corners. CS, Niko |
1.91
Hi, Got the SW100 ED before 6 years, No issue like this. Last year I faced stars elongated in some corners, I unscrewed the focuser, flush it forward a little to perfectly contact the body then tighten the screws again, Problem solved.. It is better to upload untouched image here to clarify the issue. CS! |
