It is supposed to do background gradient correction, of course
Before (print screen of stretched unlink STF just after Channel Combination). Green gradient on the left, green gradient in the middle, magenta on the right and blue on the bottom...
And after MultiscaleGradientCorrection:
Very nicely removed, especially the green gradient. I used DBE then + SCNR 100% green for some final background neutralization and got the result, which is great in my opinion. All gradients probably removed, at least at this stage of image processing.
The settings that work best for me after many tests are:
Gradient Scale: 192 - which is significantly different from the default but it certainly depends on your equipment.
Structure Separation: 2
Model smoothness: 2
The rest are defaults.
After some final adjustments in Photoshop and LRGB combination I think I was able to achieve some decent result: https://www.astrobin.com/eym0ts/
My opinion? It's not a revolution, probably with some advanced DBE we should get the same effect, but it certainly shortens the whole photo processing.
If you want to try processing the above image yourself: https://astrophotomarket.com/en/image-details/30/barnard-150-the-running-shadow - here are master lights files available for free download. Maybe you will find better settings and results!
SpectrometricFlux settings for the data:
I'm curious what your feelings are after testing this new tool and whether it will be included in your workflow?
