Autoguiding question for an AVX mount Generic equipment discussions · Oscar · 1/8/2023 · 7 · 457 · 0
messierman3000 6,29
1/8/2023
·  Bağlantıyı paylaş
I have a 1000mm Newtonian on an AVX mount, and a EOS R5 camera.
Is autoguiding strictly necessary when first starting out in astrophotography with an AVX mount (and with such a long focal length)?
Beğen
andreatax 8,85
1/8/2023
·  1 beğeni
·  Bağlantıyı paylaş
If you keep your exposures short and you are very good with your polar alignment you won't need autoguiding. Obviously how long they need be depends also on the position of the object you're imaging in the sky and how well the mount tracks.
Beğen
messierman3000 6,29
Konu başlatıcı
1/8/2023
·  Bağlantıyı paylaş
Okay. I think experimenting with the exposure time is the best choice for me then. Thank you.
Düzenlendi 1/8/2023
Beğen
Juno16 4,48
1/8/2023
·  2 beğeniler
·  Bağlantıyı paylaş
It can depend on the copy of mount you  have.
I know several folks using the AVX and they are not all the same (as are many mass-produced Chinese mounts).
I used to own an AVX (my first mount) and started imaging with a 714 focal length refractor. I PA’ed well (Sharpcap) and limited exposure to 30-45 seconds. Still I had to toss about 40% of the frames due to horrible star trailing, probably due to stiction (they all had trailing, but 40% were completely unusable).
I started guiding and it made a world of difference. I could increase exposure time to several minutes and didn’t have to toss many frames. Never got great stars, but they were acceptable enough for my experience level.
You might get decent enough tracking using short exposures at 1000mm without guiding, but you will have to see how well your mount performs.
If you have a large number of unusable frames, there is a good chance that guiding will help.
Jim
Düzenlendi 1/8/2023
Beğen
messierman3000 6,29
Konu başlatıcı
1/8/2023
·  1 beğeni
·  Bağlantıyı paylaş
Jim
I will test it.
If it doesn't work out for me, I was thinking of buying an ASIAIR mini with an orion starshoot autoguider and scope
https://www.telescope.com/Orion-StarShoot-AutoGuider-amp-60mm-Guide-Scope-Package/itemGUID/711d4a7bb49d4c9294576da200ad0a16/p/115000.uts
What do you think?
Düzenlendi 1/9/2023
Beğen
Juno16 4,48
1/9/2023
·  1 beğeni
·  Bağlantıyı paylaş
Check out this by Agena Astroproducts concerning attoguiding.
https://agenaastro.com/articles/guides/selecting-a-guide-scope-and-autoguiding-camera-for-astrophotography.html
The Orion package should work well. My first autoguiding setup was an orion Magnificent Mini Autoguider. It’s a 50 mm guide scope/ SSAG package that might be a bit pricey, but works very well and was really easy for me to setup.
I’ve had it for five years and it works very well with my 102mm refractor.
I have heard a lot about the ASIAir, but I am a N.I.N.A. fan. The Orion should work fine with the ASIAir.
If your AVX acts up when imaging unguided, the guider should help a lot. Also, if you plan to get deeper into AP, guiding will be a must.
Good Luck!
Jim
Beğen
TurtleCat 4,62
1/9/2023
·  1 beğeni
·  Bağlantıyı paylaş
Jim
I will test it.
What do you think?
The Orion guide scope is fine but if you plan to use an ASIAIR then the Orion camera (which is very old and obsolete IMO) isn’t compatible. You might consider one of the ASI mini cameras instead. There are several options available. For good or bad, with an ASIAIR you need to stay with ZWO products.
Beğen
messierman3000 6,29
Konu başlatıcı
1/10/2023
·  1 beğeni
·  Bağlantıyı paylaş
@TurtleCat
I will get a zwo asi120mm mono guiding camera instead, with an asiair mini.
@Juno16
I will read the agena article.
Thank you.
Düzenlendi 1/10/2023
Beğen
Kayıt ol ya da login to create to post a reply.
