Has anybody already tested RisingCam filter wheel: AFW? Generic equipment discussions · Stephane Perroud · ... · 30 · 1253 · 13
TheSpice 0.90
ok,
after deactivating/deinstalling the filterwheel in the windows device manager and reconnecting, it is finaly working.
And for the record, the wheel is moving in both directions
TheSpice 0.90
Hi again,
How did you guys close the M2.5 Holes on the OTA side of the filterwheel?
In my package they only supplied M2.5x8 screws which i suspect are used to screw the AFW against the camera.
WhooptieDo 9.24
Andreas:
Hi again,
That's where your OAG attaches.  I have a QHY OAG-M attached there. The pattern lines up.
You will need more backfocus anyways, so I'd just buy a spacer kit from QHY or similar.
astro_photog 0.00
Not yet, I've only done there might be more popular filter wheels from established brands that have been reviewed more extensively.
sperroud 0.00
Andreas:
Hi again,
Hi Andrea,
As I do not use OAG, I covered the thread holes with a ZWO darkening ring.
I added a M54 spacer on the OTA side, because I attached the camera with screws. Because I miss 1mm spacing normally done with the camera adapter that I do not need.
Note that my stainless steel M54 spacer almost cover the thread holes! If it was 1mm bigger in diameter, I could avoid adding the second darkening ring on the OTA side.
TheSpice 0.90
Stephane Perroud:
Hi Andrea,
Hi Stephane,
I hadn't realised that the holes on the other side are also open. I think I will also screw the camera to the AFW and use the M54 to M42 adapter on the other side. I will probably seal the OAG holes from the inside with lens head screws. Hopefully no light will get in there. Maybew i will order these ZWO darkening rings.
cs
