Dear Askar owners,
I am having a hell of a time finding a focuser to replace the stock focuser that is not working well at all at a dark sky site. Feathertouch does not make a focuser for this scope, Moonlight's focuser includes a rotator, which is going to add length to an already long telescope, increasing issues with imaging near Zenith, I don't want to spend $3200 for Optec's option, and finding adapters for the Esatto 3" (the focuser I think will best fit my needs and budget) and the Pegasus Prodigy microfocuser is very difficult as I am not sure what size I would need when customizing adapters using Precise Part's website.
Has anyone replaced the Askar 130PHQ's stock focuser with another focuser/EAF? I control everything via NINA and ASCOM.
Thanks! Jerry
Jerry Gerber: Moonlight's focuser includes a rotator, which is going to add length to an already long telescope, increasing issues with imaging near Zenith, why can't you add a pier extension? and, with or without the moonlight, your length wont be the same when you're focused?
I might be able to. I'll have to speak to the tech at the dark sky site.
I can tell you the moonlite focuser works very nicely on my PHQ 130. Reach out to Ron and tell him about your length concerns. I have had him create custom spacers in the past.
I use the Primaluce Sento Senso 2 on my 130PHQ/ZWO ASI6200MM/CFW-7/Pegasus rotator with the stock focuser, no problem.
Jerry Gerber: Dear Askar owners,
Thanks! Jerry The moonlight focuser should not add any length to your scope Jerry. What determines the length of your scope is the focal length / focal ratio you are working on at the time. Using a moonlight focuser or the native focuser is not going to change where your camera sensor needs to be to achieve focus in relation to your objective lens, at least not on the PHQ since all the glass is inside the OTA ahead of the focuser.
This thread got me interested because it would be amazing to have an electronic rotator on my 130PHQ. So I was checking out the Moonlite NiteCrawler and oh my god...$2900. That's the literal cost of my 130PHQ. I think it will be awhile before I could justify a purchase like that to myself. Good luck though on your path. I'll follow this thread to find out what the end result is.
Ashraf AbuSara:
Thanks! Jerry The moonlight focuser should not add any length to your scope Jerry. What determines the length of your scope is the focal length / focal ratio you are working on at the time. Using a moonlight focuser or the native focuser is not going to change where your camera sensor needs to be to achieve focus in relation to your objective lens, at least not on the PHQ since all the glass is inside the OTA ahead of the focuser. Hi Ashraf, I'm not referring to the focal length but rather the actual physical length of the telescope and image train. It's already fairly long and requires a pause before meridian to avoid hitting the pier. Unless we are able to use a pier extension it's probably not going to work, at least that's what Ed is saying.
Chuck Faranda: I use the Primaluce Sento Senso 2 on my 130PHQ/ZWO ASI6200MM/CFW-7/Pegasus rotator with the stock focuser, no problem. That's exactly what I am using now but the stock focuser is not able to consistently achieve focus in a fairly harsh environment. I need a higher quality focuser for imaging, for visual use the Askar focuser is fine.
Jerry Gerber:
Ashraf AbuSara:
I'm not referring to the focal length but rather the actual physical length of the telescope and image train. Jerry, let me simplify this for you with your stock focuser, when you become focused on a star, and you measure the length from the front of the scope dew shield to the back of the camera, for the sake of my explanation I'll just say that you measured 36 inches now, if you were to replace the stock with the Moonlight, and you get focused on a star again, and if you measured the front of the dew shield with the back of the camera, you would still get 36 inches yes, nothing changed, the physical length is the same; of course, in my comparison example, I'm not counting focus drift from temperature fluctuations EDIT: but, it's different if you plan to slew to the zenith with your focuser racked all the way out or, past the correct focus position - I don't know if a moonlight will work for you if you do that
This thread got me interested because it would be amazing to have an electronic rotator on my 130PHQ. So I was checking out the Moonlite NiteCrawler and oh my god...$2900. That's the literal cost of my 130PHQ. I think it will be awhile before I could justify a purchase like that to myself. Good luck though on your path. I'll follow this thread to find out what the end result is. You don’t need to replace the stock focuser to get a rotator. Depending on your needs, you could add a Pegasus Falcon or Optec Aquila to your imaging train. Jerry’s issue is he needs to replace the stock focuser and one option is to replace it with one that has a built in rotator.
also, Jerry, assuming the Moonlight is heavier than your stock focuser, you also have the advantage of heavier weight at the back of the scope
that means, in order to get balanced on the mount, the scope will need to be shifted slightly forward, which gives you even more space at the back of the scope (from the camera to the floor or whatever you're worried your scope will hit when pointing to zenith)
Oscar:
Jerry Gerber:
Ashraf AbuSara:
EDIT: but, it's different if you plan to slew to the zenith with your focuser racked all the way out or, past the correct focus position - I don't know if a moonlight will work for you if you do that That's exactly the problem. Slewing and tracking beyond an altitude of 78 degrees requires that I be very careful.
Oscar: also, Jerry, assuming the Moonlight is heavier than your stock focuser, you also have the advantage of heavier weight at the back of the scope
that means, in order to get balanced on the mount, the scope will need to be shifted slightly forward, which gives you even more space at the back of the scope (from the camera to the floor or whatever you're worried your scope will hit when pointing to zenith) If that's the case I may be in luck!
Jerry Gerber:
that means, in order to get balanced on the mount, the scope will need to be shifted slightly forward, which gives you even more space at the back of the scope (from the camera to the floor or whatever you're worried your scope will hit when pointing to zenith) If that's the case I may be in luck! be careful though, I don't know how much heavier it is compared to the stock
Jerry Gerber:
that means, in order to get balanced on the mount, the scope will need to be shifted slightly forward, which gives you even more space at the back of the scope (from the camera to the floor or whatever you're worried your scope will hit when pointing to zenith) If that's the case I may be in luck! The NiteCrawler is much heavier than the stock focuser so there will be balancing to do. There may also be a need for an additional counterweight but you’d need to evaluate that based on what you have in place now.
This thread got me interested because it would be amazing to have an electronic rotator on my 130PHQ. So I was checking out the Moonlite NiteCrawler and oh my god...$2900. That's the literal cost of my 130PHQ. I think it will be awhile before I could justify a purchase like that to myself. Good luck though on your path. I'll follow this thread to find out what the end result is. You could use a Sento Senso 2 and add the ARCO rotator which isn't outrageously priced but requires either an Esatto or Sento Senso to function.
Jerry,
Did you reach out to Primalucelab and ask about an Esatto adapter for the Askar? They may already have one.
Jeffery Richards: Jerry,
Did you reach out to Primalucelab and ask about an Esatto adapter for the Askar? They may already have one. Yes, they do not make an adapter for the Askar 130PHQ. I'd have to have it custom made. Same with Feather Touch. Moonlight does however make all the needed adapters and Ron has been responsive to my questions. I suppose with high quality and good service comes higher cost!
Jerry Gerber:
Ashraf AbuSara:
Unless we are able to use a pier extension it's probably not going to work, at least that's what Ed is saying. Like others mentioned, the physical length of your scope as a refractor is going to be determined by your focal length. All things being equal, whether you use your native focuser or the moonlight, the distance between the back of your camera and the tip of the front of your scope should remain the same when in focus.
Ashraf AbuSara:
Jerry Gerber:
Ashraf AbuSara:
Unless we are able to use a pier extension it's probably not going to work, at least that's what Ed is saying. Like others mentioned, the physical length of your scope as a refractor is going to be determined by your focal length. All things being equal, whether you use your native focuser or the moonlight, the distance between the back of your camera and the tip of the front of your scope should remain the same when in focus. Yes, I see that now. The issue is width, not length. We're trying to determine if this is going to work.
Jerry Gerber:
Ashraf AbuSara:
Jerry Gerber:
Ashraf AbuSara:
Unless we are able to use a pier extension it's probably not going to work, at least that's what Ed is saying. Like others mentioned, the physical length of your scope as a refractor is going to be determined by your focal length. All things being equal, whether you use your native focuser or the moonlight, the distance between the back of your camera and the tip of the front of your scope should remain the same when in focus. Yes, I see that now. The issue is width, not length. We're trying to determine if this is going to work. I see. What is the issue with the width? I have a very long Refractor with the TOA-130 and the NC. I also have a relatively small mount with the HAE69ec. I did end up putting a couple of risers.
Jerry Gerber:
Ashraf AbuSara:
Jerry Gerber:
Ashraf AbuSara:
Unless we are able to use a pier extension it's probably not going to work, at least that's what Ed is saying. Like others mentioned, the physical length of your scope as a refractor is going to be determined by your focal length. All things being equal, whether you use your native focuser or the moonlight, the distance between the back of your camera and the tip of the front of your scope should remain the same when in focus. Yes, I see that now. The issue is width, not length. We're trying to determine if this is going to work. If you’re using NINA, there is (or at least used to be) a Smart Meridian Flip plugin that allowed you to customize how long to image after (or pause before) by Dec (corresponding to altitude). Takes a little work, but you could use this to customize your flips to delay at decs where pier collision is a risk, and image up to or past the meridian at safe decs.
I understand that your focuser is not working well due to dust ingress and causing issues, if this is correct, then can I ask how a new focuser going to cope with that same dust ingress any better, an option maybe is to get a new focuser the same from Askar if they would sell you one, and then fit some sort of material cowling over the focuser tube, with maybe an elasticated fit at either end so it can expand and contract with the focuser, and stop probably 99% the dust ingress. Just an idea..
Maybe something like this, it’s a very very rough drawing but you get the idea  |
