What scope would you choose coming from a rasa? | |
Takahashi Epsilon 130
Takahashi Epsilon 160
Sharpstar Hypergraph
Newton with Starizona Nexus
RASA11
![]() 1/25/2024
Hi folks! Up until now I have been using a Rasa 8 and love it! After some initial struggles with tilt, it ended up being a well tuned photon sucking machine. But! I have come to yearn for more! Especially a bit more FL, even at the cost of some speed (but not slower that F4). Also, I would love to properly put my asi2600mm to use with a FW. So, I was wondering what you guys went for after your Rasas? Have you been looking back? Thanks in advance! christopher |
![]() 1/25/2024
3
What is your budget? If no concern you could consider a PW DeltaRho 350.
![]() 1/25/2024
Budget-wise <6k$. Portable would be preferable, so the delta rho, although a sweet scope would be a bit too much.
![]() 1/25/2024
The options you listed aside from the RASA 11 and Starizona Nexus are more or less lateral moves that allow you to use a filter wheel. The RASA 11 gets you more focal length, but then you are still stuck changing the filters. The only way the Nexus allows you to increase your focal length is if you use it on a large newtonian, think 250mm+ of aperture. I have no experience with the Nexus so I cannot speak towards its quality. I would suggest searching astrobin for newt + nexus combos to see if you like the image quality. You might just have to accept that with current 'budget' options, a higher focal length comes at the cost of a higher focal ratio. |
![]() 1/25/2024
If you do not mind collimation or diffraction spikes, then I would go for a Newton f4, 1000mm. You get most bang for your bucks.
![]() 1/26/2024
I have the Epsilon 160 and it is a fantastic scope. The two biggest issues people have with the Epsilon series is 1) Collimation and 2) Tilt. Collimation gets easier and easier the more you do it and understand how the scope works. If you go this route the Takahashi collimation tools are absolutely required. Since you have found a way to mitigate tilt with the RASA the Epsilon shouldn't be hard to deal with. I use the ASG Photon Cage and adjusting for tilt is super easy with it. The Octopi is another device people use for the Epsilon to deal with tilt. If you do decide on an Epsilon I recommend the 160. It has the newest corrector and it the best adjusted for small pixel cameras like your ASI2600. The 130 is nice since it is a little bit lighter and easier to grab and go but I had no issues taking my 160 along with me to my imaging site. I love my Epsilon so much that it is currently at a remote facility so I can actually use it since it is so cloudy where I am! The Sharpstar HNT13028 or 15028 is alternative for the Epsilon series but I have no firsthand experience with them. Just by browsing images of them on here, I think the Epsilon series produces sharper images. |
![]() 1/27/2024
Thank you all for your replies! This pretty much consolidates what I have been gravitating towards…a Tak! Have a great weekend! cheers Chris |
![]() 6/6/2024
So you guys are saying I'm probably nuts to consider moving from a TAK TSA-120 to a RASA 8? Because that's exactly what I began daydreaming about a little while ago and decided to see what RASA users were saying and came across this thread! FXF |
![]() 6/6/2024
If you are used to the RASA8 then I would recommend RASA11 as next step. You can go for widefield with a 24x36frame camera (alignment is a bit tricky, but doable - I do it myself) and also for a quite small FOV with a (as example) ASI183 or ASI585 camera. Results are excellent, mono cameras work with either manual filter change or for some cameras like 183 series with the mini filter wheel from ZWO. That´s just my personal experience.... you need to get used to that setup, it needs some work before the results are fine, but the results are excellent. CS Georg |
![]() 6/6/2024
A real upgrade would be something like a 12" F/4 ONTC newtonian or similar quality newt, optical/mechanical quality wise and resolution wise. The Epsilons are just that... taks (not really an upgrade over RASA8 especially aperture wise) RASA 11 is just bigger but without filter wheel and automation its not that "big" of an upgrade. I would avoid the nexus reducer, for a newtonian you are better off with a quality F4 native that can correct a nice large sensor than a "faster" but smaller correction. For 6k budget a nice quality newt is probably your best bet for what you are looking for. |
![]() 6/6/2024
F. X. Flinn: I have the RASA 8. I wold very much like a TSA-120 for visual and long FL, but I would still keep the RASA for short FL. It's like camera lenses: You dont replace a tele-lens with a wide angle lens or vice versa. |
![]() 6/6/2024
Go the Epsilon (I have the 130) - you can use a filter wheel and there is a 1.5x extender if you want a little more reach.
![]() 6/6/2024
I'd go Epsilon 160 or a 200mm f4 newt if you have the mount for it.
![]() 6/12/2024
I'll second George's RASA11 comments. Not sure why anyone would voluntarily give up f/2 speed for longer focal length. If what you mean is that you want more resolution for chasing smaller objects, then a RASA11 + 183 camera might fit well. The native resolution of a RASA11 + ASI183mcPro (OSC) is 0.799 arcsecs, drizzled 0.399 arcsecs, with a field that's ~1 degree. That seeing limited resolution + medium sized field is a joy to work with. Image quality can be nice as you'll tend to crop close to the optical axis. If you ignore the classic Mono vs OSC food fight, and you have access to dark skies, you might discover that OSC work can actually be quite acceptable with the combo. If you're stuck in the city, then of course you'll need a mono/filters approach that would lead in another direction. From your page, I see you've imaged a lot of wide fields. A RASA11+183 combo is suited for smaller nebula and galaxies. You can do larger planetaries as well. For typical examples of a RASA11 + 183 OSC targets/fields, you might search out pages with this combo (including my page). Best of luck as you consider your options... DougS https://www.astrobin.com/users/dmsummers/ |
![]() 6/12/2024
Keep the RASA and get a color camera, so that will take away the need of the FW. I do narrow band with my RASA, but I don't mind the filter change since I use only one filter per session. you can buy a 8:" RC for a longer FL and intermedia FL since you can add a reducer and FW. The Starizona reducer L works well with the RC. The RASA 11" is nice, but it is not really portable, so unless you have an observatory, I don't recommend it . The same for a 10" RC |
![]() 6/12/2024
A RASA with an OSC camera is significantly slower than an F/3 newtonian with a mono camera and is more similar in speed to a mono camera on an F/5 refractor.
![]() 6/12/2024
Luka Poropat: Sorry, I disagree with this statement. I have both RASA 8 and F/5 refractor (using a reducer). Using my ASI 294mC with both RASA and refractor, a comparable ADU value is 120s vs 300s |
![]() 6/12/2024
Rodrigo Roesch:Luka Poropat: You can disagree all you want but you can't read. He said that an OSC RASA is more similar in speed to a MONO camera on an F/5 frac. You are not considering the impacts (significant) of the Bayer matrix. It is a square of 2 green, 1 red, and 1 blue pixels. This is especially important because nebulae emit light on specific emission lines. So he is correct, an F/3 Newt absolutely gaps an 8" Rasa. Not to mention actually being able to automate imaging and avoiding buying shifted filters. Not even close. They're on two different tiers. Not even considering optical quality. |
![]() 6/12/2024
Doug Summers: Tell me that you don't understand the Bayer matrix without actually telling me. Please don't give advice to people trying to make good choices when your sources are based outdated equipment, and not relevant to a mono discussion. |
![]() 6/12/2024
Christopher: Either a larger Wynne corrected full frame Newt (f3.8), or one of the Tak Epsilons if you're okay with paying the premium for filters. Avoid Chineseium scopes like Sharpstar/Celestron. People fanboy for them but their galleries don't back it up. They have a lot of issues and your enjoyment in this hobby will increase if you avoid them! |
![]() 6/12/2024
Tell me that you don't understand the Bayer matrix without actually telling me. Please don't give advice to people trying to make good choices when your sources are based outdated equipment, and not relevant to a mono discussion. Well, the same could be said right back at you. Maybe do yourself a favor and read the following and then do some calculations. Here's a good place to start: https://www.cloudynights.com/topic/682340-monochrome-vs-one-shot-color-%E2%80%93-by-the-numbers-please/ CS Doug |
![]() 6/12/2024
Christopher: I think you should be more careful with your comments, Chinese brands would also produce good images. I also have seen bad images taken with premium scopes, and most of the time narrows down to processing skills, integration time and the LP. and much less to equipment. |
![]() 6/12/2024
Doug Summers:Tell me that you don't understand the Bayer matrix without actually telling me. Please don't give advice to people trying to make good choices when your sources are based outdated equipment, and not relevant to a mono discussion. The post you've sent is based on very old and outdated cameras, and also, discredited by the first reply. lol https://www.cloudynights.com/topic/682340-monochrome-vs-one-shot-color-–-by-the-numbers-please/?p=9743345 You ought to read the discussion and not just the OP... Edit: Also CL is not a good source. It is 2-3 years behind the curve in AP knowledge. |
![]() 6/12/2024
Doug Summers:Tell me that you don't understand the Bayer matrix without actually telling me. Please don't give advice to people trying to make good choices when your sources are based outdated equipment, and not relevant to a mono discussion. I hadn't realized that the QE curves of the latest cameras are far and away so much better than the cameras I've noted for examples. Oh wait, they aren't! Your statements are just deflection. Here's a 6200mm QE chart that shows the exact same story. There's no major difference as you suggest. As for the CN posts, you obviously didn't read past the first post. FYI, there are 6 pages and a calculator to explore.... try again please.... The story hasn't changed in the last 2-3 years! ![]() |
