![]() 3/11/2024
I took the Leo galaxy cluster in the best conditions, all images were very sharp, the guiding worked excellently at very low values, around 0.6". When processing the WBPP, the following error message occurred with StarAligment: “Scanning star data: done38 stars. integration:Structure map: done Detecting stars: done 522 stars found. Minimum star size: 16 px * Computing global linear transformation * Target image: limiting to 47 brightest stars Matching stars: done [i] [/i]*** Error: Unable to find an initial linear transformation.<* failed *> So I couldn't do the SpectrophotometricColorCaibration SPCC in PI either. The values for the ImageSolver were correct for both RA and DEC as well as for ImageScale. Does anyone from the experienced PI users have an idea what mistake I made?? I would be very happy to receive an answer that solves the problem. CS Johannes |
![]() 3/11/2024
This may not be the solution, but my image solving was failing earlier this week and it was because my focal length value had been changed. Maybe just double check that the value is entered correctly.
![]() 3/11/2024
I suspect, looking at your other images in your profile, that your PSF is far too large for the target magnitude (this seems to be confirmed by the minimu stars size). Try to lower that in the ImageSolver form to something like 16 or such and see what happens.
![]() 3/11/2024
Not that it really changes anything if you use ColorCalibration.
![]() 3/11/2024
Hi Johannes, I found a post on the PixInsight forum that may be of help; https://pixinsight.com/forum/index.php?threads/registration-error-unable-to-find-an-initial-linear-transformation.21991/ Cheers, Johan |
![]() 3/11/2024
Katelyn Beecroft: Thanks, Kathelyn, but this wasn't my mistake, I specified the focal length correctly. CS |
![]() 3/11/2024
andrea tasselli: Hello Andrea, what is "PSF"? |
![]() 3/11/2024
![]() 3/11/2024
![]() 3/11/2024
Hello Tian, that is the solution. It worked great. Thanks!! CS Johannes |
![]() 3/11/2024
andrea tasselli: This is probably going to be the answer you need. |
![]() 3/11/2024
You're welcome.
![]() 3/11/2024
Johannes Teupen: Hi Johannes, Have you tried opening a master light file, then opening the FITS header for it (File | FITS header), and dragging the triangle from the FITS header box to the image you're trying to plate solve? Once you do that, run Image Solver. If it runs successfully, you'll be able to run SPCC on your image. Sorry, I think I tried to solve the wrong problem for you! This solution will come after your StarAlignment... apologies. Greg |
![]() 3/11/2024
I would also check to see that the fits file has the correct (or close to correct) RA and Dec. If those are way off due to some error in acquisition, it will fail. I then typically do a blind solve in other software and then edit the RA and Dec in the fits header and then rerun image solver. It will then work. They really need to not assume that the RA and Dec in the header are close and initiate their own blind solve if it looks like they might be off. Other SW does this so I find it odd that something as sophisticated as PI does not. |
![]() 3/11/2024
Be also aware of the fact that resolution changes when using drizzle files! I.e. you must divide focal length or pixel size by 2.
![]() 3/11/2024
Wolfgang Bernhardt: Hmmm...was totally unaware of this. I use APP to stack...PI to post process. I usually stack using drizzle in APP. I haven't had a problem solving for the most part in PI (save the one time I input the FL incorrectly). Will have to play around with the settings to see if this changes anything but again...havent been having a problem solving with my stacks so far. |
![]() 3/16/2024
![]() 3/16/2024
First I stacked in APP, then Image Solver and thereafter SPCC in PI. I have already solved the problem with the help of Tian Tian: I have activated the online star catalog PPMXL
