Replacement motor for EQ6R-Pro Sky-Watcher EQ6-R · Tõrva Astronoomiaklubi · 1/17/2024 · 32 · 1237 · 3
Astronoomiaklubi 0.00
1/17/2024
So I took my EQ6R-Pro for a drive tonight and found that my DEC axis is not moving. After a while I discovered that the stepper motor shaft has snapped in two.  Inside the motor itself. I don't really know the cause, but it is currently -22 in here Estonia. So that probably played a role.
My question is to where could I find a replacement motor from Europe? Astroshop.eu sells EQ6-Pro motors (without the R) that seems to be different. At least by the look of the gear and plate on top of it. And I can't find a one for EQ6R-Pro, which uses a belt instead of gears. It seems weird considering EQ6R-Pro popularity.
All the help is appreciated.
PS: since the motor is pretty much useless, in the meanwhile I'm gonna try to fix it. I work as a mechanic, so I'm gonna try to tack weld it together and turn it on the lathe for the fun of it...
andreatax 8.84
1/17/2024
Just get an equivalent stepper. The motor should have part number to look for.
Searching for the number:
gives me this: https://uk.farnell.com/astrosyn/y129/stepper-motor-1-8deg-12v/dp/9598642
But is it the one or not?
Edited 1/17/2024
andreatax 8.84
1/17/2024
According to several sources it is, old model stepper.
Astrokles 3.21
1/17/2024
Maybe it will help to ask Skywatcher (Synta) whether they supply a replacement motor.
Good luck!
Could you share the sources?
Astrokles 3.21
1/17/2024
Estonia
Unit 3, Woolpit Business Park Woolpit, Bury St. Edmunds, Suffolk IP30 9UP, UK
phone: +44 1359 244200
fax: +44 1359 244255
website: www.opticalvision.co.uk
email: [email][email protected][/email]
The above information comes from this website:
https://www.skywatcher.com/where-to-buy/
Edited 1/17/2024
andreatax 8.84
1/17/2024
Tõrva Astronoomiaklubi:
[email protected] | NEQ6 Stepper Motor board upgrade
Other sources:
Motherboard HM6GT-F00-10 (EQ6-PRO) - Budapest Telescope Centre (tavcso.hu)
Source of replacement stepper:
Skywatcher Replacement RA Stepper Motor For EQ6 Pro - Rother Valley Optics Ltd
andreatax 8.84
1/17/2024
To be honest any 200 step NEMA 17 that fits the envelope and with an enough torque would do.
Other sources:
I'm sorry to say, but I struggle to see how your claim could come from these sources. First link deals with motherboards, second is the place where you can buy the motherboards and the third takes us to a place where you can buy EQ6-pro stepper replacement motors (RA, not DEC).
What is the requirement for torque for EQ6R-Pro DEC motors and what does fit the envelope?
andreatax 8.84
1/17/2024
Other sources:
The motherboard uses that stepper hence the P/N is -10 instead of -1. Ditto for the second link. The third is just a page for both motors, the Dec one is on the bottom of the page and they are the same.
andreatax 8.84
1/17/2024
Is the one quoted by the manufacturer. If you were a bit more adventurous you would have found the dimensions and relevant diagram in the same page.
Otherwise contact SW. Good luck.
Finally found some places. It seems that EQ6R-Pro shares motors with AZ-EQ6 and the RA and DEC axes are the same.
France: https://www.pierro-astro.com/materiel-astronomique/accessoires-astronomie/pieces-detachees/moteur-ad-ou-dec-pour-monture-az-eq6-ou-eq6-r_detail
Hungary: https://tavcso.hu/en/product/MotorAZEQ6ra
Spain: https://www.pierro-astro.com/materiel-astronomique/accessoires-astronomie/pieces-detachees/moteur-ad-ou-dec-pour-monture-az-eq6-ou-eq6-r_detail
karlchen800 0.00
1/18/2024
Try this,
https://teleskop-austria.at/MotorEQ6dec_Ersatzmotor-fur-EQ6-PRO-DEC-Achse
Zer0G 0.00
1/18/2024
As suggested any nema 17 stepper with the same coil resistance will probably fit.
aleksandar.milacic@gmail.com 0.00
1/18/2024
I have the same mount since 2019. It serves me well. But when I see this, I'm thinking should I buy a spare part in case the stepper dies...
Do you guys know how often does the stepper cause issues?
ThierryBoufflet 0.00
1/18/2024
Ho Torva, you can find it here. There are importator for Europ of SW.
https://www.telescopes-et-accessoires.fr/moteur-dec-ra-pour-monture-eq6-r-az-eq6-sky-watcher-c2x34407604
Paulo 0.00
1/18/2024
Hello Torva,
I had the same problem :/
I ordered a replacement motor on telescopes-et-accessories.fr, the model given by Thierry.
Check the tension of the 2 belts. I think that originally they are too tight.
philippe.vanbinst@skynet.be 0.00
1/18/2024
bellavia 1.81
1/18/2024
I did a search and cannot find the On-Step conversion kit for an EQ6R-Pro.
That would be a last resort effort. (link to On-Step, V4, below).
We just upgraded a CGE Pro with an On-Step conversion kit from Chad Gray, and it's awesome:
https://chadgray.info/cge-pro-bolt-on-stepper-motor-conversion-kit/
I am sorry this happened to you, and I hope you get the replacement motor quickly and everything works after that.
Please keep us posted
I want to build [another] tracking equatorial mount, and might use this to do it.  If it works, I will freely share the plans
https://www.terransindustry.com/collections/onstep-v4-kit
Steve
1/18/2024
Paulo Ribeiro Da Silva:
Hello Torva,
I dismount so many times EQ6R  mount and you need to verify the belt tension every time you mount them. It's difficult to explain how to find the good tension. They need to be tight with en little bit of side game.
Edited 1/19/2024
padraig 1.20
4/22/2024
Must be the time for this failure …
Dec motor shaft snapped the other night like above.
Probably self inflicted as I tightened up belts about a year ago.
( but my guiding did improve a lot …until now 🥴 )
Edited 4/22/2024
OakleyMatt 0.00
5/16/2024
Did you get this sorted in the end? Ive come across this thread because my RA motor shaft snapped yesterday on my EQ6R Pro. I agree there seems to be plenty of outlets that stock the geared version but none that stock the belt driven motor.
Anyway, Ive ordered a replacement from the first link in this thread, its meant to arrive tomorrow, unsure whats going to turn up, there's also the electrical connections side of things that to be correct, so hopefully we'll see tomorrow when it arrives.
Matt
DarkSky7 3.81
5/16/2024
Matt-let us know if you get it working again and how it runs;  This is not good news for us EQ6-R owners!
Tom
