Hello and good afternoon. I have a question about powering the asi air plus. It says in the manual that it requires a minimum of 12V power supply but it doesn’t state the maximum it can handle. I have a a power cable that provides 15V. Would that be a lot and burn the circuits or is that ok? How do you guys power your asi air? |
9.53
As long as the power supply is between 12-13 volts you will be fine. The power cable is rated for 15 volts. |
Per the ZWO website the ASIAIR Plus is rated for 9-15vdc, so I would be careful with an adaptor that provides exactly the max power rating I would double check it's output with a volt meter to ensure it isn't providing over 15v. FAQ #5 https://astronomy-imaging-camera.com/product/asiair-plus/ |
