I would like to ask your opinion and feedback for my take on the pleiades. I had some issues adjusting the reducer, basically never got it to work perfectly, so egg stars it is. What would you do differently on the image? Thank you for some honest feedback https://astrob.in/mrhjep/0/ Tobias |
1.20
Tobias, Nice image. I would try a different type of stretch like Generalized Hyperbolic Stretch, which can better resolve the bright stars, they look blown out now. Also, the blue areas in the lower part of the Pleiades seem weak for some reason, and the color in the nebula seems a bit green and not enough saturation (although this is probably a taste thing). Probably a lot of folks boost the blue in the nebula a little using masks. Try using SPCC to get a good baseline on the color. Lastly, use noise reduction, NoiseXterminator works very well, as does EZDenoise, and even Topaz Denoise AI (if used properly). Not that my image is spectacular, but you can see what I'm talking about: https://www.astrobin.com/w5qspe/C/ Hope this helps, -Pete |
10.18
Hi Tobias, This is a great image already, the nebula color and star color are nice and beside the star shape you mention, which is not very pronounced either, the star size is good. The two major things I would personally do would be: 1- some slight noise reduction. You got some apparent noise in the dark areas. 2- it could be my screen, but it seems that you have some red tint in your dark background so I would play on the red curve to correct that. Not sure how you process the stars and nebula, separately or together, but if you can process them separately and dial down on the stretch of the stars that would keep the larger stars from bloating too much. In PI there are different blending formulas you can use that can help you achieve smaller stars and have a natural/smooth blending. If you're interested, this is my most recent version of M45 Nick |
Pete Bouras: Dear Pete, thanks a lot for your comments. I was using 3 types of stretch in parallel to see which version comes out best. Manual stretch, EZ soft stretch and masked stretch. But i guess i need to play with Generalized Hyperbolic Stretch as it was recommend quite often. The weak blue was somewhat of a choice as i tried not to oversaturate and keep M45 nicely transitioned with the surrounding nebulae. As per noise reduction i am using the manual jon rista approach which is basically EZ Denoise. But maybe overall i was too shy with color saturation and denoising. thanks again Tobias |
Nick Large: Dear Nick thank you for your feedback. Now i can also see some red in the background. I always struggle with seeing these subtle things when you spent countless hours working on an image. Its is hard to be able to get fresh eyes, even when some time has passed. As per denoising, i agree the background could use a little more. awesome feedback Nick thx Tobias |
John Favalessa: John, wow thanks for the deep analysis in terms of sensor distance. I spent several nights adjusting the reducer and sensor distance however it never seemed to work. I either was too close or too far away from the sensor although i used to distance settings provided by WO. The adjustment ring is wobbly on my reducer with quite some play in the thread. Maybe that is the issue. But still, it shouldnt be so off, as you showed, the corner stars are quite ugly. I also have the flattener without reducer and there is no tilt. So it must be the reducer. I used the recommended 15.6 mm on the reducer and a backfocus of 70.6 mm. During adjusting i plates with backfocus and the reducer distance. How the pixel scale came to be i am not sure. The image was drizzled in processing it should be slightly over 1 arcs/ pixel. all of you again thanks a bunch. Now i have new approaches to try out. clear skies Tobias |
13.23
those are the correct distances for the 102gt and the WO reducer. Your filter is 1mm thick so that means you should add 0.33 to the backspace. The wobble is the big concern. that shouldn't have play, should be locked down with no flex. I'm sure that's adding the tilt. I'd contact who you bought it from for advice/repair/replacement. -john |
