Which forth 571 sensor model to get? | |
Mono | |
OSC | |
2.94
Hi all, My Touptek camera of 571 mono arrived and delivered to me today, it is my second mono of 571 but as third one of 571 sensor [i have one OSC too], and now if i will use 4 identical scopes to do SHO LRGB then which forth 571 i should get, a third mono or a second OSC? if i get a second OSC then i can use a dual band filter with it so that leave my other two mono for Lum and SII, and a second OSC is for only RGB, or do you prefer i go with third mono so each SHO is done alone, but then i won't do Lum unless the target isn't requiring to have all channels of LRGB and SHO, under my Bortle sky NB and Lum needs to be long time integration. |
